Andrew736 Opublikowano 4 godziny temu Zgłoś Opublikowano 4 godziny temu Fielding in MLB The Show 26 feels less forgiving when a hard grounder moves away from your defender's first step. You will notice it quickly, especially against strong hitters. A useful place to spend your MLB 26 stubs is on roster improvements that raise defensive range, speed, and reaction. Still, ratings alone will not fix poor positioning. Your controller setup matters just as much, and a few changes can make every defensive possession feel more predictable. Set Up Control Before You Chase Better Ratings Start with Button Accuracy for throws. It gives you a clear timing point and helps avoid rushed releases when a runner is moving. Keep Auto Infielder Jump Reactions and Auto Infielder Dive Reactions enabled if you want assistance with the first animation. Those options can save a step on sharp liners. Turn off broad Auto Fielding and Auto Throwing, though, so you decide where the ball goes and how quickly the transfer begins. If you prefer complete control, disable jump and dive assistance as well. Try one change at a time. Otherwise, you may not know which setting actually helped. Read Directional Reactions, Not Just Overall Ratings The new reaction categories deserve a closer look. A shortstop may look excellent on paper but still feel slow when the ball travels toward his backhand side. Check left, right, forward, and backward reaction values before assigning a player to a key spot. Speed helps once the fielder is moving, while reaction controls how quickly that movement starts. Center fielders need coverage in several directions. Shortstops need quick lateral movement and reliable hands. Do not treat one strong number as proof that a player fits every defensive role. Position Ratings to Prioritise Why It Matters Center Field Speed, forward reaction, range Helps close gaps on balls hit into the alleys Shortstop Lateral reaction, hands, acceleration Supports quick stops and faster throws across the diamond Third Base Right reaction, arm strength Useful against hard-hit balls and long throws Make Positioning Do Some of the Work Defensive alignment is often the easiest improvement to overlook. Watch the hitter's tendencies, then move your fielders before the pitch. A modest shift can turn a difficult running catch into a routine stop. Avoid moving everyone too far in one direction, since contact can still land in the open space. Against pull hitters, protect the likely lane while keeping enough coverage for a soft line drive the other way. Your aim is simple: reduce the distance your defender must travel. Check directional reaction ratings before choosing a defensive position. Use small pre-pitch adjustments rather than extreme movement. Keep Button Accuracy active if you want more control over throws. Practise jump and dive timing in low-pressure situations. Build a Defence That Fits Your Style There is no single setting combination that suits every player. Some users want assisted first movements, while others would rather control every launch. Test your choices in several innings and pay attention to the moments when a fielder hesitates. If the issue keeps appearing on one side, compare the relevant directional rating instead of replacing the whole lineup. A well-placed defender with sensible settings can outperform a higher-rated player who starts from the wrong spot. When you are ready to adjust the roster around this approach, MLB 26 stubs for sale can support the next upgrade without taking attention away from the defensive fundamentals. 0 Cytuj
