Tak ku przestrodze
https://www.otomoto.pl/oferta/suzuki-sv-650ccm-2007-rok-ladna-zadbana-okazja-sprawdz-ID6yCXln.html#xtor=SEC-8
i do porównania z https://www.check-mot.service.gov.uk/
Check the MOT history of a vehicle
Registration number: RA07AKZ
  • Vehicle make SUZUKI
  • Vehicle model SV650S
  • Date first used 19 June 2007
  • Fuel type Petrol
  • Colour Blue
MOT history of this vehicle
  • Test date 24 October 2015
  • Test Result Fail
  • Odometer reading 75,363 miles
  • MOT test number 2397 7808 3946
  • Reason(s) for failure
    Rear Brake pad(s) (sintered type) less than 1.0mm thick (3.2A1f(ii))
    Rear Roller brake test indicates a binding brake (3.3.A1a)
    Front suspension has excessive corrosion which reduces the strength of a load bearing member or its supporting structure. (2.3.8)
    Front suspension assembly excessive wear or free play in a front suspension component (2.3.4)
    Front Tyre tread depth is below minimum requirements of 1.0mm (4.1.3(ii))
  • Advisory notice item(s)
    Rear Brake disc(s) slightly worn (3.2.A1l)
    Front Roller brake test indicates slight fluctuation of brake effort (3.3.A1d)
    Front Brake disc(s) slightly worn (3.2.A1l)
    Oil leak
    Engine very noisy
